[gdal-dev] RPFTOC driver question
Martin Chapman chapmanm at pixia.com
Sat Aug 25 23:04:45 PDT 2012
Yehiyam,
Thanks for that feedback.  I’ll take it out too unless Even has a good
reason to keep it in there.  I am interested to know what his thought
process was when he stuck it in and whether he got it out of the
specification of did it on his own.  Do you guys use a lot of CIB or CADRG
or both?
Best regards,
Martin
From: Livneh Yehiyam [mailto:yehil at rafael.co.il]
Sent: Saturday, August 25, 2012 11:10 PM
To: Martin Chapman; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] RPFTOC driver question
Martin
We have removed the check completly, and so far have not had any problems.
We have come to the conclusion that it is too restrictive.
Yehiyam
Sent from my mobile
Subject: [gdal-dev] RPFTOC driver question
Date: 26 אוגוסט 2012 06:46
Even,
I have an RPF dataset (CIB 5Meter in Zone 1) that will not display using the
RPFTOC driver because on line 605 of file
gdal19\gdal\frmts\nitf\rpftocdataset.cpp in function
RPFTOCProxyRasterDataSet::SanityCheckOK(GDALDataset* sourceDS) the line of
code:
WARN_CHECK_DS(fabs(adfGeoTransform[GEOTRSFRM_TOPLEFT_X] - nwLong) < 1e-10);
Fails.
Where:
adfGeoTransform[GEOTRSFRM_TOPLEFT_X] = 32.036011080332401
and
nwLong = 32.036035630999997
which equals -0.000024550667596
and is then greater than 1e-10.
I was wondering why this sanity check is there?  Do you think I have some
bad frame files or a bad toc file?  If so, why would you reject the entire
boundary from rendering?
By the way, thanks a ton for creating this driver.
Best regards,
Martin
  _____
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE
SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential information
intended for a specific individual and purpose, may constitute information
that is privileged or confidential or otherwise protected from disclosure.
If you are not the intended recipient, you should contact us immediately and
thereafter delete this message from your system. You are hereby notified
that any disclosure, copying, dissemination, distribution or forwarding of
this message, or the taking of any action based on it, is strictly
prohibited. If you have received this e-mail in error, please notify us
immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or
destroy any and all electronic or other copies of the original message and
any attachments thereof.
  _____
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120826/e3ef547c/attachment-0001.html>
