[gdal-dev] Compile GDAL with HDF4 and Shapefile-Support (64bit)
Even Rouault even.rouault at mines-paris.org
Tue Aug 28 05:33:09 PDT 2012
Selon David1980 <dleimbach at zebris.com>:
> the version from FWTools
> has HDF4, but no Shapefiles
FWTools has definitely shapefile support. The shapefile driver doesn't require
external libraries, so every GDAL/OGR build has shapefile support.
C:Program FilesFWTools2.4.7>ogrinfo --formats
Supported Formats:
  -> "ESRI Shapefile" (read/write)  <--- look here
  -> "MapInfo File" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "DGN" (read/write)
etc etc...
