[gdal-dev] OGR WFS WFSLayerMetadata broken
Jeremy Palmer JPalmer at linz.govt.nz
Wed Aug 29 21:26:14 PDT 2012
I'm trying to setup a simple python script to query the WFS layers from a service. When using the special WFSLayerMetadata layer it seems to get screwed up. After the first comma within an abstract is found the field alignment becomes broken..
If I look here http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/wfs/ogrwfsdatasource.cpp#L1221 it seems the fields are being double quoted before being included into temp CSV data
This is the place where the temp mem CSV layer is actually created:
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/wfs/ogrwfsdatasource.cpp#L242
any ideas?
See script below.
---script---
import ogr
import gdal
wfs_drv = ogr.GetDriverByName('WFS')
gdal.SetConfigOption('OGR_WFS_LOAD_MULTIPLE_LAYER_DEFN', 'NO')
# Note: if you want to use the URL below you need to sign up at
# data.linz.govt.nz and create yourself an API key...
ds = ogr.Open('WFS:http://wfs.data.linz.govt.nz/<my-private-key>/wfs')
layermetadata = ds.GetLayerByName("WFSLayerMetadata")
feat = layermetadata.GetNextFeature()
while feat is not None:
    name = feat.GetFieldAsString('layer_name')
    title = feat.GetFieldAsString('title')
    print( "%s, %s" % (name, title) )
feat = None
exit(0)
---script---
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
