[gdal-dev] Building gdal 1.9.1 on AIX with
Thu Aug 30 23:17:52 PDT 2012
On 12-08-30 10:01 PM, chen zhen wrote:
> Hi All,
> I met a compile problem when trying to build gdal 1.9.1 on AIX
> platform with xlc toolset. Here is the compile log:
> make[2]: Entering directory `/home/sdb/BeyonDB_20/ads_3rlib/gdal/frmts/ers'
> /bin/sh /home/sdb/BeyonDB_20/ads_3rlib/gdal/libtool --mode=compile
> --tag=CXX xlc_r -q32 -q32  -Wall
> -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/port
> -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/gcore
> -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/alg
> -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/ogr
> -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/ogr/ogrsf_frmts -I../raw
> -DOGR_ENABLED -I/home/sdb/BeyonDB_20/ads_3rlib/gdal/port
> -I/home/sdb/BeyonDB_20/ads_3rlib/jpeg/temp
> -I/home/sdb/BeyonDB_20/ads_3rlib/jpeg/temp/include
> -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp
> -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp/include  -c -o
> ../o/ersdataset.lo ersdataset.cpp
> libtool: compile:  xlc_r -q32 -q32 -Wall
> -I/home/sdb/BeyonDB_20/ads_3rlib/zlib/temp/include -c ersdataset.cpp
> -o ../o/ersdataset.o
> xlc_r: 1501-289 (W) Option -Wall was incorrectly specified. The option
> will be ignored.
> "ersdataset.cpp", line 690.41: 1540-0207 (S) No common type found for
> operands with type "CPLString" and "const char [4]".
> "ersdataset.cpp", line 691.42: 1540-0207 (S) No common type found for
> operands with type "CPLString" and "const char [6]".
> "ersdataset.cpp", line 692.42: 1540-0207 (S) No common type found for
> operands with type "CPLString" and "const char [7]".
> "ersdataset.cpp", line 1048.51: 1540-0207 (S) No common type found for
> "ersdataset.cpp", line 1049.52: 1540-0207 (S) No common type found for
> "ersdataset.cpp", line 1050.52: 1540-0207 (S) No common type found for
> make[2]: *** [../o/ersdataset.lo] Error 1
> make[2]: Leaving directory `/home/sdb/BeyonDB_20/ads_3rlib/gdal/frmts/ers'
> the correspond source code in ersdataset.cpp is :
>      oSRS.importFromERM( osProj.size() ? osProj : "RAW",
>                          osDatum.size() ? osDatum : "WGS84",
>                          osUnits.size() ? osUnits : "METERS" );
> It seems the compiler can't convert a CPLString to a const char []
> format. However there is a cast operator in CPLString declaration:
>      operator const char* (void) const { return c_str(); }
> I am not sure why the xlc compiler can't recognize this cast
> operation, maybe it think const char [] and   const char * are
> different?
>   I modified the source code a bit which does an explicit cast, it at
> least passed the compiling.
>      oSRS.importFromERM( osProj.size() ? (const char *)osProj : "RAW",
>                          osDatum.size() ? (const char *)osDatum : "WGS84",
>                          osUnits.size() ? (const char *)osUnits : "METERS" );
> I  am looking for if there is any way working around this issue(such
> as adding a compile parameter to xlc) or should this be a patch that
> mkes gdal playing will on AIX?
Zhen,
I don't know why this confuses xlc but the work around is harmless
enough so please feel free to submit a patch via trac once the build
completes successfully.
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
