[gdal-dev] projection issue with GDALCreateGenImgProjTransformer
Hare, Trent thare at usgs.gov
Wed Dec 5 09:17:22 PST 2012
Kees,
   Just an initial guess. It looks like you are using a km radius when it
should in meters - +a=6378388.0
-Trent
On Wed, Dec 5, 2012 at 3:11 AM, Kees Kling <ckling at upcmail.nl> wrote:
> Hi all,
> I'm trying to reproject an image.
> source projection = `+proj=stere +lat_0=90.0 +lon_0=0.0 +lat_ts=60.0
> +a=6378.388'
> I already used this projection in other parts of my project, but then in
> combination with OGR. Here I don't have problems, but if I use it with gdal
> in the function  GDALCreateGenImgProjTransforme**r, I'm getting the error:
> ERROR 1: Failed to import coordinate system `+proj=stere +lat_0=90.0
> +lon_0=0.0 +lat_ts=60.0 +a=6378.388'
> What am I doing wrong
> Regards
> Kees Kling
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121205/6f552a72/attachment.html>
