[gdal-dev] "Too many points" for GDALSuggestedWarpOutput with Ozi .map
Nik Sands nixanz at nixanz.com
Wed Dec 5 13:19:23 PST 2012
Thanks for the reply.  Just to clarify though, can you tell me what it is that is wrong about it?
I expect the user might come back to me and say, "but it works fine in OziExplorer", which I don't have to test with. The projection "Latitude/Longitude" appears to be a valid Ozi projection, so I'm guessing that you mean it doesn't fit with the other data in the file?
On 05/12/2012, at 6:06 PM, Jean-Claude Repetto <jrepetto at free.fr> wrote:
> On 05/12/2012 03:53, Nik Sands wrote:
>> Hi GDAL devs,
>> I have a problem with GDALSuggestedWarpOutput producing an error.  It works for most of the files I've thrown at it, but I have one file that a user has sent me for which the error occurs.  The file in question can be downloaded for testing at:  https://dl.dropbox.com/u/12436846/715lkmaps.zip
> The projection declared in the .map file is wrong.
> Jean-Claude
