[gdal-dev] EPSG 8.0 Upgrade
Jeremy Palmer JPalmer at linz.govt.nz
Thu Dec 6 10:12:10 PST 2012
HI Frank,
Thanks that's great news. Has this upgrade now started supporting data shift grids, such as NZGD2000<->NZGD1949?
Cheers
Jeremy
________________________________________
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
Sent: Thursday, 6 December 2012 1:18 p.m.
To: PROJ.4 and general Projections Discussions; GeoTIFF; gdal-dev; metacrs at lists.osgeo.org
Subject: [gdal-dev] EPSG 8.0 Upgrade
Folks,
At the request of Howard Butler, I have upgraded PROJ.4, libgeotiff, and
GDAL to use the EPSG 8.0 database in development "trunk".
This was accomplished, as usual based on the process described here:
   http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
Amoung other things this will result in some datums having new preferred
datum shift solutions.  Upgrade with care.
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
