[gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
Kevin F Webb kfw4 at cornell.edu
Thu Dec 6 10:59:05 PST 2012
Any suggestions Even? Permissions aren't an issue, same user executed all commands, LD_LIBRARY_PATH is identical, ld.so.conf was updated before the 2 builds, and ldd shows that the link files are all locatable.
________________________________________
From: Even Rouault [even.rouault at mines-paris.org]
Sent: Thursday, December 06, 2012 1:53 PM
To: Kevin F Webb
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
Le jeudi 06 décembre 2012 19:48:34, Kevin F Webb a écrit :
> attached
> Thanks Even!
Your file works me for both GDAL trunk and GDAL 1.9.0, so I suspect there is
something wrong in your setup, or something else ...
