[gdal-dev] EPSG 8.0 Upgrade
Fri Dec 7 11:03:05 PST 2012
Jeremy,
Unfortunately I do not automatically pickup references to grid shift files
from the EPSG database.  To the extent these are supported it is
accomplished by special hackery. In fact skimming the epsg file, I think
the only datum for which grid shift files are used *by default* is NAD27.
Perhaps this would be a good time for me to review how to utilize at least
the grid shift files we are distributing with PROJ.4 like ntf_r93.gsb and
nzgd2kgrid0005.gsb.
Hmm, I am getting the impression that nzgd2kgrid0005.grd is actually the
transformation between NZGD2000 and WGS84 and that we would actually need
another file - possibly something like Nzgd49ToNzgd2K.gdc to support
NZGD1949 - is that right?
I'd suggest you file a ticket in the PROJ.4 Trac on this issue with
suggestions on how to proceed.
Best regards,
Frank
On Thu, Dec 6, 2012 at 10:12 AM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
> HI Frank,
> Thanks that's great news. Has this upgrade now started supporting data
> shift grids, such as NZGD2000<->NZGD1949?
> Cheers
> Jeremy
> ________________________________________
> From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org]
> On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
> Sent: Thursday, 6 December 2012 1:18 p.m.
> To: PROJ.4 and general Projections Discussions; GeoTIFF; gdal-dev;
> metacrs at lists.osgeo.org
> Subject: [gdal-dev] EPSG 8.0 Upgrade
> Folks,
> At the request of Howard Butler, I have upgraded PROJ.4, libgeotiff, and
> GDAL to use the EPSG 8.0 database in development "trunk".
> This was accomplished, as usual based on the process described here:
>    http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
> Amoung other things this will result in some datums having new preferred
> datum shift solutions.  Upgrade with care.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://home.gdal.org/warmerda
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121207/fa512b33/attachment-0001.html>
