[gdal-dev] EPSG 8.0 Upgrade
Roger Bivand Roger.Bivand at nhh.no
Sun Dec 9 00:32:13 PST 2012
Frank
Would it be possible to document which version of EPSG is being used by
setting #define (s) somewhere? It would be very helpful to be able to inform
users that a change may occur, and give them access to the version of the
installed copy? I'll look at thinking of a way, but I think this would make
results more reproducible?
Best wishes,
Roger
Frank Warmerdam wrote
> Jan,
> I think the easiest place to see them highlighted is in the changeset
> applied to the PROJ.4 epsg init file:
>   http://trac.osgeo.org/proj/changeset/2294
> Best regards,
> Frank
> On Thu, Dec 6, 2012 at 2:13 AM, Jan Hartmann <
> j.l.h.hartmann@
> > wrote:
>>  Hi Frank, where do I find which datums have new datum shift solutions?
>> Jan
>>  On 12/06/2012 01:18 AM, Frank Warmerdam wrote:
>> Folks,
>> At the request of Howard Butler, I have upgraded PROJ.4, libgeotiff, and
>> GDAL to use the EPSG 8.0 database in development "trunk".
>> This was accomplished, as usual based on the process described here:
>>   http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
>> Amoung other things this will result in some datums having new preferred
>> datum shift solutions.  Upgrade with care.
>> Best regards,
>> gdal-dev mailing list
> gdal-dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam@
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev at .osgeo
Roger Bivand
NHH Norwegian School of Economics, Bergen, Norway
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-EPSG-8-0-Upgrade-tp5021086p5021645.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
