[gdal-dev] EPSG 8.0 Upgrade
pcreso at pcreso.com pcreso at pcreso.com
Sun Dec 9 01:17:51 PST 2012
Extending this slightly - so it can more easily be discovered by less technically capable users, & in binary distributions of GDAL.
Is it possible to have a command line parameter for GDAL/Proj (etc) that tells the user what EPSG version is installed? Perhaps include this information in the -version option?
gdalinfo --version
GDAL 1.9.1, released 2012/05/15 - using EPSG vX.X
Thanks...
   Brent Wood
--- On Sun, 12/9/12, Roger Bivand <Roger.Bivand at nhh.no> wrote:
Subject: Re: [gdal-dev] EPSG 8.0 Upgrade
To: gdal-dev at lists.osgeo.org
Date: Sunday, December 9, 2012, 9:32 PM
Frank
Would it be possible to document which version of EPSG is being used by
setting #define (s) somewhere? It would be very helpful to be able to inform
users that a change may occur, and give them access to the version of the
installed copy? I'll look at thinking of a way, but I think this would make
results more reproducible?
Best wishes,
Roger
Frank Warmerdam wrote
> Jan,
> I think the easiest place to see them highlighted is in the changeset
> applied to the PROJ.4 epsg init file:
>   http://trac.osgeo.org/proj/changeset/2294
> Best regards,
> Frank
> On Thu, Dec 6, 2012 at 2:13 AM, Jan Hartmann <
> j.l.h.hartmann@
> > wrote:
>>  Hi Frank, where do I find which datums have new datum shift solutions?
>> Jan
>>  On 12/06/2012 01:18 AM, Frank Warmerdam wrote:
>> Folks,
>> At the request of Howard Butler, I have upgraded PROJ.4, libgeotiff, and
>> GDAL to use the EPSG 8.0 database in development "trunk".
>> This was accomplished, as usual based on the process described here:
>>   http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
>> Amoung other things this will result in some datums having new preferred
>> datum shift solutions.  Upgrade with care.
>> Best regards,
>> gdal-dev mailing list
> gdal-dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam@
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev at .osgeo
Roger Bivand
NHH Norwegian School of Economics, Bergen, Norway
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-EPSG-8-0-Upgrade-tp5021086p5021645.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121209/a3f23717/attachment.html>
