[gdal-dev] GDALSimpleSURF improvements
Howard Butler hobu.inc at gmail.com
Sun Dec 9 17:59:58 PST 2012
Any chance you could generate a patch or (even better) a pull request for this from http://github.com/OSGeo/GDAL ?
GDAL 1.10 is coming quite quickly, and I'd be happy to do some of the configuration effort to integrate this if there's a clean pull request to merge.
Thanks,
Howard
On Dec 9, 2012, at 4:31 PM, Seth Price <seth at pricepages.org> wrote:
> I just found some bugs and made some algorithm improvements. New code can be downloaded from the same location.
> ~Seth
> via iPhone
> On Dec 8, 2012, at 2:21 AM, Dmitry Baryshnikov <polimax at mail.ru> wrote:
>> Hi Seth,
>> I'll test our code and try to patch GDAL if it possible.
>> Regards,
>> Dmitry
>> 08.12.2012 3:02, Seth Price пишет:
>>> I've worked the FLANN library into GDALSimpleSURF for a massive speedup
>>> and made some other minor speed improvements mainly related to setting
>>> constants as the right type and moving invariants outside of loops.
>>> You can grab the updated source here. Please add it to whatever repository
>>> is appropriate.
>>> http://seth1.bluezone.usu.edu/flann_surf.tgz
>>> Thanks,
>>> Seth
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
