[gdal-dev] gdalwarp performance with many GCPs
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Dec 12 04:24:02 PST 2012
Hi Knut,
What do you mean by "very slow"? I regularly use gdalwarp -tps on much
larger rasters with a few thousand gcp-s, and never noticed unacceptable
delays. Do you have very little physical memory, or many parallel
processes running?
Jan
On 12/12/2012 01:12 PM, Knut-Frode Dagestad wrote:
> Hi list,
> When warping images with many GCPs, the -tps switch (Thin Plate
> Spline) is found to be necessary to get decent accuracy. This makes
> however warping very slow. The only method I found to increase speed
> is the -et switch, but at cost of spatial accuracy.
> Below some comments about the other tries which did not help:
> - compiling GDAL with armadillo support had no effect on speed.
> Btw, to compile with armadillo I had to manually insert -llapack in
> the following line in configure:
> if test -z "`${CXX} testarmadillo.cpp -o testarmadillo -larmadillo
> 2>&1`" ; then .....
> Perhaps ${LIBS} should be added permanently to this line in trunk?
> - compiling GDAL with OpenCL had also no effect. At first surprising,
> but looking at the opencl warp kernel it seems that it only makes a
> difference for other resampling algorithms than nearest neighbour?
> - Increasing  memory with -wm had no effect
> - Using several threads (-multi -wo NUM_THREADS=ALL_CPUS) actually
> increased computing time significantly (my proj version is 4.7.1).
> From the debug output, a lot of the time is apparently spent on:
> "WARP: Copying metadata from first source to destination dataset"
> Is this an indication that much time is simply spent on reading and
> writing the GCPs to/from file? If so, we could perhaps expect improved
> performance if Geolocation Arrays could be used instead (not possible
> due to http://trac.osgeo.org/gdal/ticket/4907).
> The tests are made with the following file and command on Ubuntu:
> http://dl.dropbox.com/u/15885758/testgcp.tif  (3212 GCPs and 2048x2511
> pixels covering Southern Europe)
> time gdalwarp --debug on -et 5 -tps -t_srs '+proj=merc' testgcp.tif
> out.tif  (+ other swithces mentioned above)
> Best regards from Knut-Frode
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121212/9617a560/attachment.html>
