[gdal-dev] Can GDAL be configured to do direct I/O? (bypass cache, control blocksize, etc)
Ethan Alpert ealpert at digitalglobe.com
Fri Dec 14 06:14:44 PST 2012
I'm running in to a situation where I believe the filesystem cache
settings are screwing things up. Based on iozone tests I'm not getting
near the throughput I should for large 4gb+ files with multiple writing
processes. It is a complex interaction of the number of dirty pages in
filesystem cache in combination with small blocksize of the filesystem.
I'm still trying to figure this out but I can now get these machines to
tip over with just iozone.
I'm actively working on how to refactor this code base to use GDAL
WriteBlock but in absence of a solution there I'm wondering if there's
anyway to get GDAL writing using O_DIRECT?
Thanks,
-ethan
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121214/40130a00/attachment-0001.html>
