[gdal-dev] image Compilation of Qgis 1.8 with gdal svn (Windows7_64bits)
Joaquim Luis jluis at ualg.pt
Mon Dec 17 18:29:33 PST 2012
2. The errors shown at this step are not really errors. They show up
like that because the Dependency could not find them since the directory
where they reside is not on your system's path (qgis works because a
batch file sets the path before calling the qgis.exe). So basically,
don't worry about them
3. Sorry, this is more difficult. You said in your first mail that you
had built the GDAL dev and to do that one must know how to change the
nmake.opt file. Not that it's difficult, but are you able to build the
GDAL SVN (dev)? Because if you didn't this whole exercise is pointless.
(but to answer the question, just set
VERSION = 19
> Hello,
> Thank you for your reply. For information, The currently qgis version has
> been installed
> via OSGeo4W_install (advanced install).
> 1.Ok i installed the "Dependency Walker"
> 2.I loaded in the Dependency walker the qgis.exe located in
> C:\OSGeo4W\apps\qgis\bin. I
> have a few error messages when i load the file. Please find in attachment
> the SS
> representing the interface&  error messages.As you know  this qgis version
> has been
> installed via OSGeo4W_install (advanced install). If this method of
> installation may
> explain those error meessages, i can uninstall it&  install again qgis this
> time with the
> classic install (binaries) way if it's necessary...?
> 3. I found the nmake.opt at C:\OSGeo4W\usr\src\src\gdal-1.9.2. I send you by
> this file. Sorry but i have a doubt regarding the edition of the file. Could
> you give me
> details regarding this step please?
> Thank you to throw light for me.
> Regards.
> <http://osgeo-org.1560.n6.nabble.com/file/n5023624/SS_error_message_dependance_walker.JPG>
> nmake.opt<http://osgeo-org.1560.n6.nabble.com/file/n5023624/nmake.opt>
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Compilation-of-Qgis-1-8-with-gdal-svn-Windows7-64bits-tp5022355p5023624.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
