[gdal-dev] GDAL contour
Geoff Shipton geoff at tritonimaginginc.com
Wed Dec 19 15:00:35 PST 2012
I am considering using GDAL contour as a way to generate bathymetry
contours.
Can anyone point me to a bit more information than is available here:
http://www.gdal.org/gdal_contour.html
For example what is available as file types for <src_filename>?  It seems to
work just fine for .TIF images are there any other file types?
The  -f option supports .DXF outputs, are there others? (apart from
shapefiles)
Many thanks and happy Christmas!
Geoff Shipton,
Triton Imaging Inc.
Customer Support.
Capitola CA.
 <mailto:geoff at tritonimaginginc.com> geoff at tritonimaginginc.com
The information contained in this message may be privileged or confidential
information intended solely for the use of the addressee(s).  Any views or
opinions presented in this communication do not necessarily represent those
of Triton Imaging, Inc.  If the reader of this message is not the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited.  If you have received
this communication in error, please immediately notify me and you are hereby
instructed to delete all electronic copies and destroy all printed copies.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121219/240c2d24/attachment.html>
