[gdal-dev] Feature styles units in dxf export
Marco Hugentobler marco at sourcepole.ch
Fri Dec 21 00:16:13 PST 2012
Hi
Exporting vector symbology from QGIS, I encountered problems with (line
width) units in the dxf export.
Setting a style string in mm (e.g.  'PEN(c:#0000ff,w:5mm'), the dxf
driver converts the 5 mm to 0.005 ground units, then multiplies that by
100 (most likely because in dxf, one width unit is 1/100 mm). This seems
strange to me, shouldn't the driver treat mm as paper units (instead as
ground units) and just multiply the mm by 100?
Thanks,
Marco
