[gdal-dev] GCP reprojection
Fabian Schindler fabian.schindler at eox.at
Fri Dec 21 05:55:15 PST 2012
Hi devs,
Sorry for the noise, I figured it out. Seems like it worked all along
with order 1, but I was just to blind to see.
Regards,
Fabian
On 12/18/2012 04:12 PM, Fabian Schindler wrote:
> Sorry for the traffic, just forgot to say that with the command line
> utilities it works as expected:
> gdal_translate -gcp 0 0 16.1 48.5 -gcp 604 0 16.168 48.5033 -gcp 604
> 297 16.168035 48.4835 -gcp 604 594 16.16804 48.4636 -gcp 0 594 16.1001
> 48.46 -gcp 0 297 16.1 48.48 input.jpg tmp.tif
> gdalwarp -order 1 tmp.tif output.tif
> Thanks,
> Fabian
> On 12/18/2012 04:06 PM, Fabian Schindler wrote:
>> Hey devs,
>> I've spent a full day to find a solution to this, but unfortunately
>> was not able to solve it, so you are my last hope :)
>> I'm trying to reproject an image with GCPs to a CRS specified by WKT.
>> I used  `gdal.AutoCreateWarpedVRT` to retrieve the output image size
>> + geotransform in conjunction with `gdal.ReprojectImage` to reproject
>> the image. This worked well unless I have really few GCPs at my
>> disposal (i.e: 6), then I just get the error "Failed to compute GCP
>> transform: Transform is not solvable". (Funnily it works with only 4
>> GCPs).
>> I created a small C function to get the size and geotransform from an
>> image with few GCPs (basically a small, Python callable wrapper for
>> GDALSuggestedWarpOutput) with `order = 1` which helped me around the
>> `gdal.AutoCreateWarpedVRT` error. But now I'm stuck with the
>> `gdal.ReprojectImage`, which gives me the exact same error as above.
>> ("Failed to compute GCP transform: Transform is not solvable"). I've
>> also tried to create a wrapper here to use `order=1` but this time it
>> did not help and the error stayed.
>> My raster image size is 605x595 and I want to apply the following GCPs:
>> pixel      line          lon       lat
>> 0.000000   0.000000   -> 16.100000 48.500000
>> 604.000000 0.000000   -> 16.168000 48.503300
>> 604.000000 297.000000 -> 16.168035 48.483500
>> 604.000000 594.000000 -> 16.168040 48.463600
>> 0.000000   594.000000 -> 16.100100 48.460000
>> 0.000000   297.000000 -> 16.100000 48.480000
>> Is there any (C) function I can use instead? Or any other method to
>> reproject images with few GCPs?
>> Thanks,
>> Fabian
>> P.S: I'm using GDAL 1.9.1 on CentOS 6.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
