[gdal-dev] Compression artifacts
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Dec 27 05:37:49 PST 2012
On 12/27/2012 02:27 PM, Even Rouault wrote:
> The artifacts are due to the lossy characteristics of JPEG compression that
> are particularly visible on borders between nodata pixel and valid pixels. An
> option would be to use nearblack to create a .msk mask file :
> nearblack -setmask -o big_with_mask.tif big.tif -of gtiff
> (I'm not sure if your original image has black or white nodata areas. If it is
> white, then add -white to the previous command line)
> And then do the gdal_translate with big_with_mask.tif as input (you should
> perhaps consider adding "-co TILED=YES" too), and then gdaladdo. I've just
> pushed a fix since building overviews with "--config COMPRESS_OVERVIEW JPEG --
> config PHOTOMETRIC_OVERVIEW
> YCBCR" when there's a .msk didn't work.
> MapServer should be able to use the mask file as a transparency mask.
OK Even, thanks. This means that I should use gdal-svn?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121227/fbb098c4/attachment.html>
