[gdal-dev] read a catalog is slower then directly the raster ?
Andrea Peri aperi2007 at gmail.com
Thu Feb 2 05:37:12 EST 2012
Unfortunately I was unable to test with GDB.
My skill was not enough :(
However I try other ways.
I will use a utility to test the disk activity and after put the qgis
canvas on a little portion of land covered I add the catalog.vrt.
Using this utility I can see that qggis try to open all the raster instead
of open only the single raster necessary to visualize the portion of land
in the canvas.
After this I see the xml in the catalog:
  <SourceFilename relativeToVRT="0">F:\....\216110_2010.ecw</SourceFilename>
      <SourceProperties RasterXSize="13900" RasterYSize="11760"
DataType="Byte" BlockXSize="13900" BlockYSize="1" />
      <SrcRect xOff="0" yOff="0" xSize="13900" ySize="11760" />
      <DstRect xOff="26320" yOff="140" xSize="13900" ySize="11760" />
And I notice also that the catalog don't store on every tag of a raster the
single bbox of that raster.
So qgis necessary must open all the raster to understand what raster is on
the visible portion on the canvas.
I guess this is a good reason to explain because it is so slow when in the
catalog there and many hundred of rasters.
Unfortunately I don't find any option in gdalbuildvrt to add the extension
of every raster in the catalog.
2012/1/31 Even Rouault <even.rouault at mines-paris.org>
> Selon Dmitry Baryshnikov <polimax at mail.ru>:
> > 31.01.2012 16:54, Andrea Peri ?????:
> > > Hi,
> > > using qgis I notice that it is more slow to open some raster from a
> > > catalog.vrt rather than opening the same raster directly.
> > > The slow is so big that when the catalog has many raster qgis take
> > > many time to open the catalog.
> > > Because qgis use gdal to read raster and also to read a catalog.
> > > I guess this is not an issue for qgis. But is a question of gdal.
> > > Before to start to do some test I like to know if there is some know
> > > issue on this.
> > I think this bug are mentioned in such tickets
> > http://trac.osgeo.org/gdal/ticket/2076 and
> > http://trac.osgeo.org/gdal/ticket/3482
> > QGIS more slow because it warp image (if it from VRT or have some
> > rotation in meta and etc.) and have no overviews. You can see if image
> > is warped in layer properties metadata tab -> driver.
> Yes that's one possibility. A more pragmatic way would be to run qgis under
> GDB/DDD, and when it is stuck, Ctrl+C to see in which GDAL function it is
> stuck... That should give some hints.
> > Best regards,
> >      Dmitry
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120202/9940744e/attachment-0001.html
