[gdal-dev] read a catalog is slower then directly the raster ?
Dmitry Baryshnikov polimax at mail.ru
Thu Feb 2 09:34:31 EST 2012
02.02.2012 18:10, Andrea Peri ?????:
> 2012/2/2 Even Rouault <even.rouault at mines-paris.org
> <mailto:even.rouault at mines-paris.org>>
>     Selon Andrea Peri <aperi2007 at gmail.com <mailto:aperi2007 at gmail.com>>:
>     > Hi,
>     > Unfortunately I was unable to test with GDB.
>     > My skill was not enough :(
>     Well, provided you have gdb installed, it is "just" a matter of :
>     1) "gdb qgis"
>     2) in the gdb console, type "run" and validate
>     3) when qgis is slow, switch to the console with gdb and hit Ctrl+C
>     4) in the gdb console, type "bt" (for backtrace)and validate, and
>     then it can
>     give some interesting information
>     5) to go on qgis execution, type "c" (continue) and validate
>     6) you can go to 3) again
> thx, I try it .
>     > However I try other ways
>     > So qgis necessary must open all the raster to understand what
>     raster is on
>     > the visible portion on the canvas.
>     No, what you show above is sufficient to defer the loading of
>     individual tiles,
>     until they are really necessary.
>     What I suspect is that your vrt has no associated overviews, so
>     when you open
>     qgis, it will try to display the overall coverage of the raster,
>     which then will
>     require to open each tile.
>     Try "gdaladdo your.vrt 2 4 8 16 32"
> I try to create the overview, but it is really sloow .
> After 1hours is to 0%.
> I will try with a selection of few rasters.
>     > I guess this is a good reason to explain because it is so slow
>     when in the
>     > catalog there and many hundred of rasters.
>     > Unfortunately I don't find any option in gdalbuildvrt to add the
>     extension
>     > of every raster in the catalog.
>     There's none : the above information that is generated by default
>     is sufficient.
> Sorry Roualt,
> the catalog give the start point and the number of pixel , but miss
> the size in meters or "unit of map" of every pixel so for me was not
> possible to detect the bbox of every raster.
> Perhaps in the overview there is the missing information ?
> >Best regards,
> >Even
> Thx,
> Andrea.
> Andrea Peri
> qwerty àèìòù
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
We have discussed this problem with Even. I'll fix it. The work is in
process.
Best regards,
     Dmitry
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120202/aa4a81ee/attachment.html
