[gdal-dev] Re: Extract OSM data from PostGIS using OGR
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Feb 3 02:30:00 EST 2012
Travis Kirstine <traviskirstine <at> gmail.com> writes:
> Is it possible to extract features from a OSM PostGIS / Postgres
> database (loaded with osm2pgsql)?
For sure. The osm_point, osm_line and osm_polygon tables are normal spatial
tables which can be read with GDAL Postgis driver http://gdal.org/ogr/drv_pg.html
-Jukka Rahkonen-
