[gdal-dev] Issue GDAL with JPEG-compressed TIFFS
Even Rouault even.rouault at mines-paris.org
Fri Feb 3 07:41:25 EST 2012
Peter,
Does ELGIS GDAL uses internal libtiff (4.0beta) or external libtiff (3.8 or 3.9)
? I guess it is external libtiff, and then it could explain the issues you have
with overviews and JPEG compression. There have been fixes in libtiff 4 to
better support that situation (multiple IFDs with compression). Altertantively,
you could probably workaround that by generating external overviews (add -ro to
the gdaladdo command line), but no guarantees. By the way, the --config
COMPRESS_OVERVIEW JPEG --config INTERLEAVE_OVERVIEW PIXEL --config
JPEG_QUALITY_OVERVIEW 90 options only apply to external overviews, not internal
ones.
> I'm doing quite some experiments with GDAL and image compression these days
> I do have an issue with geotiff 1.3/gdal 1.8.1 on CentOS 6 with packages
> from ELGIS. The story goes like this:
> I create tiffs with
> gdal_translate -of GTiff -co COMPRESS=JPEG -co JPEG_QUALITY=90
>   -co "TILED=YES" -co "BLOCKXSIZE=512" -co "BLOCKYSIZE=512" <infile>
> <outfile>
> and then add overviews with (I do have to add the overlays in distinct
> steps, otherwise gdaladdo aborts with an error message).
> gdaladdo --config COMPRESS_OVERVIEW JPEG --config INTERLEAVE_OVERVIEW
> PIXEL --config JPEG_QUALITY_OVERVIEW 90 -r average <outfile> 3
> PIXEL --config JPEG_QUALITY_OVERVIEW 90 -r average <outfile> 9
> PIXEL --config JPEG_QUALITY_OVERVIEW 90 -r average <outfile> 27
> PIXEL --config JPEG_QUALITY_OVERVIEW 90 -r average <outfile> 81
> (Trying with power-of-2-steps gives the same result. If I drop all
> options from gdaladdo: same result).
> I'll create a WMS service with MapServer 5.6.7 and do get a big red
> square in the image. The square is "fixed" to the geografical position,
> e.g. if I move the extend the square moves too. The square is situated
> in the corner of the tiff file.
> It appears only at some scales. If I change it very slightly, the square
> remqins, if I change for more then approx 1%, it disappears.
> I've put the two images at
> http://www.r3-gis.com/gdal_issues/tiff_with_jpegcompression_and_overviews.jpeg
> and
> http://www.r3-gis.com/gdal_issues/tiff_with_nocompression_and_overviews.jpeg
> The problem disappears if I do not run gdaladdo on the images or when I
> do not use Jpeg compression:
> gdal_translate -of GTiff  -co "TILED=YES" -co "BLOCKXSIZE=512" -co
> "BLOCKYSIZE=512" <origfile> <targetfile>
> There are some hits for
http://www.google.com/search?client=ubuntu&channel=fs&q=mapserver+artefacts+in+raster+gdal&ie=utf-8&oe=utf-8,
> but mostly related to older versions of GDAL and without resolution.
> Thanks,
> Peter
> Peter Hopfgartner
> R3 GIS Srl - GmbH
> www.r3-gis.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
