[gdal-dev] Thread safe?
Even Rouault even.rouault at mines-paris.org
Mon Feb 6 18:52:44 EST 2012
Le mardi 07 février 2012 00:41:38, Even Rouault a écrit :
> Le mardi 07 février 2012 00:23:20, Billy Newman a écrit :
> > Is the DataSource.delete() method (from java binding) thread safe?
> Yes, it should
To avoid any ambiguities, you can call  the delete() method on 2 distinct
datasources"simultaneously" from 2 threads. "Of course", not on the same one.
> > Thanks
> > On Wed, Jan 11, 2012 at 3:09 PM, Even Rouault
> > <even.rouault at mines-paris.org>wrote:
> > > Le mercredi 11 janvier 2012 22:32:45, Billy Newman a écrit :
> > > > I am using a third party lib (imageio-ext) to leverage gdal in java
> > > > code.
> > > > I have noticed that the imageio-ext folks have wrapped the
> > > > gdal.Open(..)
> > > > call in a synchronized method. I am assuming this is to prevent
> > > > imageio-ext users from hanging themselves with regard to thread
> > > > safety.
> > > > I have looked at the gdal FAQ with regards to thread safety and the
> > > > last
> > > > release that it mentions additions is 1.3.0.
> > > > What is the current status of the 1.9.* build with regards to thread
> > > > safety.
> > > The following is still true : "In particular for the situation where
> > > many threads are reading from GDAL datasets at once should work as
> > > long as no two threads access the same
> > > GDALDataset<http://www.gdal.org/classGDALDataset.html>object at the
> > > same time. However, in this scenario, no threads can be writing to
> > > GDAL while others are reading or chaos may ensue. "
> > > I believe most common GDAL drivers should be safe. That includes
> > > drivers that don't depend on third party librairies (the driver is
> > > self contained in GDAL source tree), and drivers that depend on
> > > "classic" third-party libraries (such as PNG, JPEG, GIF). For other
> > > third party libraries (netCDF, HDF4, HDF5, ...), this depends on
> > > whether they are thread-safe themselves. There's at least one driver
> > > that is known to be non thread-safe
> > > : GRIB.
> > > > Thanks,
> > > > Billy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
