[gdal-dev] Copying FIDs into existing PG schema
Even Rouault even.rouault at mines-paris.org
Tue Feb 7 17:49:47 EST 2012
> Is there a specific reason for the OGRPGTableLayer::BuildCopyFields (and
> CreateFeatureViaCopy) checking that the field must exist in the layer
> FieldDefn before adding it to the copy field list? Or is this a bug?
Jeremy,
I've created http://trac.osgeo.org/gdal/ticket/4495 to capture the issue and
pushed a fix.
Note however that this area is a bit fragile since there are valid use cases
where we don't want to impose the FID and let the DB do the autoincrement (*).
The issue is that in COPY mode you must choose at the beginning if you will
set or not the FID column for all the features to be copied. So the heuristics
is now : if the first feature to be copied has a FID set, then we will also set
it for all following features. Otherwise, if the first feature to be copied has
no FID set, we will not set it and let the DB pick up a value for us for all
the features. This is hopefully a reasonable assumption. I'm afraid I have no
idea how to do it differently.
But in INSERT mode, you can freely alternate features with FID set or unset.
(*) I'm happy that we have a rich regression suite for the PG driver because
my first attemps at fixing the 'new' use case initially broke those use cases.
Best regards,
Even
