[gdal-dev] Geolocation Arrays ??
Etienne Tourigny etourigny.dev at gmail.com
Wed Feb 8 08:13:48 EST 2012
Thanks Anton,
The latitudes of this dataset span from 26.77687 to 33.82318 , so
nowhere near the poles!
I tried your suggestion, using the extents from the hdf metadata:
		:Northernmost\ Latitude = 33.82318f ;
		:Southernmost\ Latitude = 26.77687f ;
		:Easternmost\ Longitude = -79.69389f ;
		:Westernmost\ Longitude = -90.15974f ;
$ gdalwarp -geoloc -t_srs EPSG:4326 -te -90.15974 26.77687 -79.69389
33.82318f  --debug off
HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13 tmp1.tif
And casual inspection shows that the value is correctly reprojected
(the outlines of Florida are consistent).
==> Does this mean that gdalwarp -geoloc should always be used with -te option?
Etienne
On Wed, Feb 8, 2012 at 6:21 AM, Anton Korosov <anton.korosov at nersc.no> wrote:
> Hello Etienne!
> I also got such error when trying to process MODIS L1B images taken near the
> pole. Try to set some limited extent with the -te option for gdalwarp. It
> helped me, at least.
> Best regards!
> Anton
> On 02/07/2012 10:22 PM, Etienne Tourigny wrote:
>> Even, Frank,
>> thanks for your answers.  I have run into a problem with using
>> gdalwarp with geoloc transform.
>> In ticket #1895 there is an hdf file for which the HDF4 driver creates
>> GEOLOCATION metadata.
>> Trying gdalwarp on it gives an error, and the result transform is
>> incorrect.  Am I doing something wrong, or is this a bug?
>> command is : gdalwarp -geoloc -t_srs EPSG:4326
>> more info below:
>> $ gdalinfo HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13
>> Driver: HDF4Image/HDF4 Dataset
>> Files: A2006005182000.L2_LAC_SST.x.hdf
>> Size is 389, 602
>> Coordinate System is `'
>> Metadata:
>> Geolocation:
>>   LINE_OFFSET=0
>>   LINE_STEP=1
>>   PIXEL_OFFSET=0
>>   PIXEL_STEP=1
>>   SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
>>   X_BAND=1
>>   X_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":11
>>   Y_BAND=1
>>   Y_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":12
>> Corner Coordinates:
>> Creating output file that is 31119P x 5864L.
>> Processing input file HDF4_SDS:UNKNOWN:A2006005182000.L2_LAC_SST.x.hdf:13.
>> ERROR 1: Too many points (441 out of 441) failed to transform,
>> unable to compute output bounds.
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> $ gdalinfo tmp1.tif
>> Driver: GTiff/GeoTIFF
>> Files: tmp1.tif
>> Size is 31119, 5864
>> Coordinate System is:
>> GEOGCS["WGS 84",
>>     DATUM["WGS_1984",
>>         SPHEROID["WGS 84",6378137,298.257223563,
>>     PRIMEM["Greenwich",0],
>>     UNIT["degree",0.0174532925199433],
>> Origin = (-90.198287963867188,90.300000000000011)
>> Pixel Size = (0.015398926739995,-0.015398926739995)
>> Metadata:
>>   AREA_OR_POINT=Area
>> Image Structure Metadata:
>>   INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  ( -90.1982880,  90.3000000) ( 90d11'53.84"W, 90d18' 0.00"N)
>> Lower Left  ( -90.1982880,   0.0006936) ( 90d11'53.84"W,  0d 0' 2.50"N)
>> Upper Right (     389.001,      90.300) (Invalid angle, 90d18' 0.00"N)
>> Lower Right (     389.001,       0.001) (Invalid angle,  0d 0' 2.50"N)
>> Center      ( 149.4013126,  45.1503468) (149d24' 4.73"E, 45d 9' 1.25"N)
>> Regards,
>> Etienne
>> On Tue, Feb 7, 2012 at 7:05 PM, Frank Warmerdam<warmerdam at pobox.com>
>>  wrote:
>>> On Tue, Feb 7, 2012 at 7:40 AM, Etienne Tourigny
>>> <etourigny.dev at gmail.com>  wrote:
>>>> Hi all,
>>>> I would like to have information on the status of geolocation array
>>>> support in GDAL.
>>>> The relevant RFC4 (http://trac.osgeo.org/gdal/wiki/rfc4_geolocate)  is
>>>> still "under development", and the information there is that
>>>> GDALCreateGeoLocTransformer "is currently partially implemented".
>>> Etienne,
>>> I think the geoloc transformer received some fixes from someone
>>> other than myself and now is working reasonable well.  It would
>>> be desirable to freshen up the RFC and get it passed but it isn't
>>> particularly a priority of mine so I'm not likely to drive it in the
>>> very near future.
>>> Best regards,
>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | Geospatial Software Developer
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
