[gdal-dev] Re: Weird gdal2tiles performance inconsistency
    mladen-g at distributel.net
    Wed Feb  8 13:15:00 EST 2012
Hi Vadim,
Just wanted to say thanks for suggesting the tilers-tools package.
Over the past few weeks I've done some testing with it, and while it
has some minor quirks, I think it's overall a better solution for me.
I do still see the strange performance drop in low zoomlevels, but
since performance is overall much better, it's easier to tolerate.
I see on the Google code site that you're the project owner, so good job!
Regards,
Mladen
Quoting vadp.devl at gmail.com:
> Hi Mladen,
> On Fri, Dec 23, 2011 at 3:58 AM,  <mladen-g at distributel.net> wrote:
> > This takes about 16 seconds on my machine.
> > This takes 32 seconds, or about double the time of tiling zoomlevels 1-7.
> Not really an answer to your question, but if you are about a timinig
> issues for you rater processing you may give a try to gdal_tiler.py
> from http://code.google.com/p/tilers-tools.
> Regards
> Vadim
Quoting mladen-g at distributel.net:
> Hi all,
> I'm seeing some very strange performance from gdal2tiles on a
> particular grid, so I'm wondering if someone has an insight into why
> this is happening.
> The problem is that when I tile the grid at zoom level 7, I get much
> better performance than with other zoomlevels, including lower ones
> The grid is this (zipped PNG, ~2.7Mb):
> http://dl.dropbox.com/u/53500018/ontarioOrigSizeTrimReprojected.zip
> So, let's say I run this command:
> gdal2tiles.bat -w google -s EPSG:4326 -z 1-7 -v
> C:\temp\ontarioOrigSizeTrimReprojected.png
> C:\temp\outputTiles
> But if I replace the last line to be zoom level 1:
> gdal2tiles.bat -w google -s EPSG:4326 -z 1-1 -v
> C:\temp\outputTiles
> 1-7.  Note also that I've experimented with other maximum zoomlevels
> (5,6,8,9,10,11) and they all run slower than 7.
> So, does anyone know Why does this strange behaviour happen on zoom
> level 7?  And is there any way to optimize the input to gdal2tiles
> for better performance?
> Regards,
> Mladen
> This message was sent using Distributel Webmail.
> Ce message a été envoyé à partir de la Messagerie Web Distributel.
