[gdal-dev] is there a way to concatenate the band in raster file name
Etienne Tourigny etourigny.dev at gmail.com
Fri Feb 10 08:00:18 EST 2012
Paolo,
This feature would have to be driver-specific, so adding it to netcdf
would not benefit other drivers (in fact not all of them support
this).
Some time ago there was a discussion about standardizing the
driver:filename syntax , it seems to have stalled. It could be a nice
addition to have the option band=<band_no> in there.
http://lists.osgeo.org/pipermail/gdal-dev/2011-October/030305.html
http://trac.osgeo.org/gdal/wiki/rfc36_open_by_drivername
Would it be worth it allowing to select multiple bands (by range or
list) such as NETCDF:file.nc:var:1-2,4
There is a similar request already for selecting multiple bands:
http://trac.osgeo.org/gdal/ticket/2540
Etienne
On Fri, Feb 10, 2012 at 9:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi all
> Using the netCDF driver, I have noticed that there is a nice syntax
> for getting the dataset and the single raster in the dataset.
> For example, in my case, for accessing the dataset:
>   $ gdalinfo NETCDF:/my/path/data/mynetcdf_dataset.nc
> and for accessing the single raster:
>   $ gdalinfo NETCDF:/my/path/data/mynetcdf_dataset.nc:myraster
> I was wondering if there is a way (that could be very useful also for
> other raster formats) to concatenate also the band, something like
> this:
>   $ gdalinfo NETCDF:/my/path/data/mynetcdf_dataset.nc:myraster:myband
> I would need this for using it in MapServer, without the need to
> create virtual rasters (that seems to be the only viable solution at
> my eyes)
> Thanks for your patience
> P
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
