[gdal-dev] Simplify a polygon topology doesn't preserve the topology
Arnd Wippermann arnd.wippermann at web.de
Mon Feb 20 16:36:37 EST 2012
I try to simplify a polygon topology (GDAL 1.9.0, released 2011/12/29).
SET INPUT="top1_bene.gml"
SET OUTPUT_01="top1_bene_sim_01.gml"
SET OUTPUT_005="top1_bene_sim_005.gml"
SET OUTPUT_001="top1_bene_sim_001.gml"
"%prgpfad%\ogr2ogr" -f "GML" %OUTPUT_01%  %INPUT% -simplify 0.1
"%prgpfad%\ogr2ogr" -f "GML" %OUTPUT_005% %INPUT% -simplify 0.05
"%prgpfad%\ogr2ogr" -f "GML" %OUTPUT_001% %INPUT% -simplify 0.01
but preserving the topology doesn't work for tolerances above a treshold.
I get a correct result for a tolerance of 0.01, but for 0.05 and 0.1
the results are only in parts correct.
see:
http://gis.ibbeck.de/OLClient/OLClient.asp?WMC=/ginfo/tests/ogr/simplify/Sim
plify_bene_ogr.wmc.xml
I have it also tried with a polygon topology of the us states and the result
wasn't great.
(I get similar results using postGis ST_Simplify.)
Apart the tolerance are there other options to consider or is it a bug?
The polygon topology consists of two polygons and the shared border have
identical vertices.
Arnd
