[gdal-dev] learning GDAL with C/C++
Tue Feb 21 15:08:50 EST 2012
Joseph,
I'd start with http://www.gdal.org/gdal_tutorial.html, the general purpose
API tutorial.  It isn't comprehensive, but I think it is fairly good for the
areas covered.
Note that GDAL does not directly help with distributed processing.  I
assume this is what you mean by running on a cluster.  You could
take care of farming out chunks yourself or have each process on the
cluster use GDAL to read chunks, but be cautious about writing to
one file from multiple processes.
Best regards,
Frank
On Tue, Feb 21, 2012 at 11:50 AM, joseph.nalluri
<joseph.nalluri at gmail.com> wrote:
> Hello All,
>  I am very pleased to find this forum. This is my first post. Please bear
> with me. In my project, I am trying to read in .bil file (hyperspectral
> image) into my C/C++ code. ( I haven't done this yet, because I am still
> trying to see, how can I do it).
>  After I read in, I run some image processing algorithms on it and perform
> this on a cluster. Is there a good tutorial/guide on this aspect, which
> could help me out.
>  Any help would be greatly appreciated. I am just starting out on this.
> Thanks,
> Joseph
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-learning-GDAL-with-C-C-tp4492722p4492722.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
