[gdal-dev] Re: Hillshade + Topographic Map??
tim martin tjmgis at gmail.com
Wed Feb 22 08:42:45 EST 2012
Hi Donovan and board
Yes that Tim Sutton tutorial is very good.
I also found this one
http://dirkraffel.com/2011/07/05/best-way-to-merge-color-relief-with-shaded-relief-map/
I ended up following this procedure and it has worked v well. I just setup
a loop to use ImageMagik and combine the two images. And then reapplied the
georeferencing using gdal_translate + world file.
Thanks to all helped, it has made me aware of lots of other options that I
may use in the future
thanks again
Tim
On 21 February 2012 19:52, Donovan Cameron <sault.don at gmail.com> wrote:
> Have you reviewed the article from Tim Sutton: "A workflow for creating
> beautiful relief shaded dems using GDAL"[1]?
> It has some valuable pointers.
> [1]
> http://linfiniti.com/2010/12/a-workflow-for-creating-beautiful-relief-shaded-dems-using-gdal/
> Donovan
> On Tue, Feb 21, 2012 at 12:29 PM, Joaquim Luis <jluis at ualg.pt> wrote:
>>  5) Looked at GMT and I cannot find the options to load two rasters on
>>> top of each other.
>> Tim,
>> You don't load the two grids on top of one-another. Illumination is NOT
>> like transparency. It uses the gradients of the grid, projects it into the
>> direction of light and than change the color in the HSV space (the
>> S(aturation) component) and converts back to RGB
>> The links that I sent you have the scripts used to produce the figures.
>> You can also look at this one for a very simple illumination in bw, but the
>> procedure for color illumination is exactly the same.
>> http://gmt.soest.hawaii.edu/**gmt/html/GMT_Docs.html#x1-**1300007.5<http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1300007.5>
>>  6) MIRONE - again cannot see how to do this from within the application.
>> Well, I can give you a 'click-recipe' if you want, but Mirone won't be
>> able to deal with the such big grids as yours.
>> Anyway, here is a step-by-step example
>> https://sites.google.com/site/**mironehowtos/basic/shade-**illuminations<https://sites.google.com/site/mironehowtos/basic/shade-illuminations>
>> ______________________________**_________________
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120222/50a74f6f/attachment.html
