[gdal-dev] Error when importing/exporting to FileGDB
tim martin tjmgis at gmail.com
Wed Feb 22 08:51:12 EST 2012
Hi gdalers
I have installed OSGeo4W and have checked the ogr formats and see that
FileGDB is there.
So I then tested a simple ESRI shapefile using the following command
ogr2ogr -f "FileGDB" region.gdb region.shp
this worked and I can see the data in ArcMap.
I then tried a folder of shapefiles using
FOR %%A in (C:\data\*.shp) do (ogr2ogr -f FileGDB data.gdb %%A)
All worked well.
Now when I try to export from PostGIS or try to load data in using python I
get the following error
ERROR 1: Error: Failed at creating table for \Text (General Function
failure)
I then get errors for the other tables etc
I have done a search and found something about using -nlt POINT on gis
stack exchange, however that did not help.
There is also a post about stating the EPSG code, which I tried using
-a_srs EPSG:27700
Neither have helped and now a bit stuck,
Anyone else seen this error or know what is causing it
thanks
Tim
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120222/d440e448/attachment.html
