[gdal-dev] SetSpatialFilter
Even Rouault even.rouault at mines-paris.org
Wed Feb 22 18:43:18 EST 2012
Le jeudi 23 février 2012 00:31:55, Ethan Alpert a écrit :
> Is it still true that the geometry used for SetSpatialFilter must have
> the same CRS as the layer?
Yes, the only OGR driver that does the reprojection that I'm aware of  is the
FileGDB driver. Other drivers will happily ignore any CRS set on the geometry
passed to SetSpatialFilter
> This electronic communication and any attachments may contain confidential
> and proprietary information of DigitalGlobe, Inc. If you are not the
> intended recipient, or an agent or employee responsible for delivering
> this communication to the intended recipient, or if you have received this
> communication in error, please do not print, copy, retransmit, disseminate
> or otherwise use the information. Please indicate to the sender that you
> have received this communication in error, and delete the copy you
> received. DigitalGlobe reserves the right to monitor any electronic
> communication sent or received by its employees, agents or
> representatives.
