[gdal-dev] undefined symbol error
Thu Feb 23 13:13:15 EST 2012
Jerl,
I would imagine you are building GDAL against modern PROJ.4
include files but linking against an older (4.7.0 or older) PROJ.4
shared library.  Likely you have another libproj.so in /usr/lib in
addition to the one in /usr/local/lib.
By the way, why are you using --with-static-proj4?
If you were to use the dynamic libproj.4 loading (the default) a
mismatch between build and runtime would not actually be a problem
because the dynamic loader adapts to the version of the shared
library it ends up manually loading.
Best regards,
Frank
On Thu, Feb 23, 2012 at 7:44 AM, Jerl Simpson <jsimpson at wxtrends.com> wrote:
> Hey guys, I just grabbed gdal 1.9 from SVN, compiled it and I am getting an
> undefined symbol error pj_ctx_alloc in many of the ./apps/ programs. I first
> noticed it with gdaldem. Everything is pointing to my build directory. I've
> tried all manner of things, not sure what to do next.
> gdal1.9NEW/apps/.libs/lt-gdaldem: symbol lookup error:
> gdal1.9NEW/.libs/libgdal.so.1: undefined symbol: pj_ctx_alloc
> any ideas?
> My configure options
> ./configure --prefix=/usr/local --with-python  --with-netcdf=/usr/local
> --with-static-proj4=/usr/local --with-geos=/usr/local/bin/geos-config
> This issue just started yesterday.  I had a slightly older version from the
> svn repository, still 1.9 and didn't have this trouble.  I'm not sure what
> might have changed on the machine to have caused this.
> Maybe there are some conflicting libaries hanging around mucking things up?
> Thanks for the help!!
> Jerl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
