[gdal-dev] Building GDAL with FileGDB support
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Feb 24 07:08:57 EST 2012
On 12-02-23 4:12 AM, Paolo Corti wrote:
> Hi Stuart
> I think I have your same configuration, for me was enough to add
> FileGDB_API/lib to the LD_LIBRARY_PATH variable, and fileGDB driver is
> working perfectly.
Paolo, can you add your note to the wiki page?
http://trac.osgeo.org/gdal/wiki/FileGDB    Thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
