[gdal-dev] VRT file from NetCDF
Yves Jacolin yjacolin at free.fr
Wed Feb 29 04:57:21 EST 2012
Even,
I understand.
Thanks,
Y.
Le Mercredi 29 Février 2012 09:54:27 Even Rouault a écrit :
> Selon Yves Jacolin <yjacolin at free.fr>:
> > Hello,
> > Sorry to come again to this thread :)
> > It seems that when using relatif file for NETCDF for instance, MapServer
> > won't
> > work correclty, see Even comment below.
> > Is it a bug from GDAL? Do I need to open a ticket about this?
> I don't see an easy fix to improve that. That would require some cooperation
> with the driver to return the filename from the connection string and to
> reform a new connection string with the full filename. IMHO not worth the
> effort, but perhaps worth documenting it for the moment.
> > Y.
> > >> Hello,
> > >> Etienne asked some question offlist so I investigate.
> > >> gdal create relatif path by default (I don't see a flag to change
> > >> this). MapServer and QGIS don't like this.
> > >MapServer and QGIS don't even know the content of the VRT, so the
> > >problem is more complex than that.
> > >If you pass a relative path to gdalbuildvrt or gdal_translate -of VRT,
> > >a
> > >relative path will be written. In which case the VRT driver should be
> > >able>
> > to
> > >recompute the full path given the location of the .vrt.
> > >On the contrary, if you pass an absolute path, it will be store as
> > >absolute.
> > >The issue here is likely with netCDF subdatasets, where the connexion
> > >string is
> > >not a file, but something like "netCDF:xxxx:a_filename", that the VRT
> > >driver cannot interpret. In that case, the resolution of relative
> > >filenames will>
> > not
> > >work. So I'd suggest you to use "netCDF:xxx:full_filename" to avoid
> > >those issues. Or you must be sure that the current directory of
> > >MapServer and QGIS is
> > >the directory of the .VRT, but you cannot always guarantee this.
> > >> After changing relatif path to absolute path both are working
> > >> correctly.
> > >> Thanks,
> > Y.
> > Yves Jacolin
> > http://yjacolin.gloobe.org
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Yves Jacolin
