[gdal-dev] drawing line using OGR and mysql in mapserver
Murat Beyhan beyhan at deprem.gov.tr
Wed Feb 29 09:34:39 EST 2012
Chaitanya,
here is the structure of table on database
sfault :
eq_id varchar(14)
lat1  decimal(7,4)
lon1  decimal(7,4)
lat2  decimal(7,4)
lon2  decimal(7,4)
lineview :
eq_id varchar(14)
geom  double
it seams geom as double
I thing it should be geometry isn't it?
may be  I have to change structure of lineview by changing following
Roberts' suggestion to create view on database
 create view lineview as select eq_id, "LINESTRING(" + lon1 + " " + lat1
 + "," + lon2 + " " + lat2 + ")" as geom from sfault
but I'm not sure for the line.
VTR for points, I have tested and works well
but for line still could not achieved yet, please give me another idea.
here is test.vrt file
<OGRVRTDataSource>
<OGRVRTLayer name="sta">
<SrcDataSource>MYSQL:stations,user=root,password=mysql_passwd,host=localhost,port=3306,tables=sta</SrcDataSource>
<SrcSQL>SELECT sta_id as name,type,latitude,longitude from sta where
type like "%SMACH%"</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and following code gives successful result as you see
ogrinfo -ro -al test.vrt
INFO: Open of `test.vrt' using driver `VRT' successful.
Layer name: sta
Geometry: Point
Feature Count: 12
Layer SRS WKT:
(unknown)
type: String (24.0)
latitude: Real (5.4)
longitude: Real (5.4)
OGRFeature(sta):0
  name (String) = 0617
  type (String) = SMACH
  latitude (Real) = 40.4569
  longitude (Real) = 32.6319
  POINT (32.631900000000002 40.456899999999997)
OGRFeature(sta):1
  name (String) = 0618
  latitude (Real) = 40.4798
  longitude (Real) = 32.4555
  POINT (32.4555 40.479799999999997)
As you see this works well.
I hope you can catch point what is wrong or lack of on my works....
Thanks again
On Tue, 2012-02-28 at 18:08 +0530, Chaitanya kumar CH wrote:
> Murat,
> I see that your view,  lineview, doesn't give the expected geometry
> type with ogrinfo. It is showing the datatype as Real. Check if the
> datatype of geom is actually string/text.
> On Tue, Feb 28, 2012 at 12:49 PM, Murat Beyhan <beyhan at deprem.gov.tr>
> wrote:
>         Chaitanya,
>         Map file which is try to draw line as follows
>         are there any problem on the code
>          LAYER
>          NAME sfault1
>          CONNECTIONTYPE OGR
>          CONNECTION '<OGRVRTDataSource>
>          <OGRVRTLayer name="lineview">
>         <SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
>          <SrcLayer>lineview</SrcLayer>
>          <GeometryType>wkbLineString</GeometryType>
>          <GeometryField encoding="WKT" field="geom"/>
>          <LayerSRS>WGS84</LayerSRS>
>          <FID>eq_id</FID>
>          </OGRVRTLayer>
>          </OGRVRTDataSource>'
>          DATA sfault1
>          STATUS on
>          TYPE line
>          CLASS
>          NAME "Source Fault"
>          SYMBOL "cline"
>           SIZE 3
>          COLOR  0 0 255
>          END
>          END
>         ogrinfo
>         sfault -summary
>         INFO: Open of
>         `MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306'
>              using driver `MySQL' successful.
>         Layer name: sfault
>         Geometry: None
>         Feature Count: 1
>         Layer SRS WKT:
>         (unknown)
>         eq_id: String (14.0)
>         lat1: Real (7.4)
>         lon1: Real (7.4)
>         lat2: Real (7.4)
>         lon2: Real (7.4)
>         **************linewiew created by following sql
>         statement:*************
>         " " + lat1
>         then
>         [murat at localhost ~]$ ogrinfo
>         lineview -summary
>         INFO: Open of
>         Layer name: lineview
>         Geometry: None
>         Feature Count: 1
>         Layer SRS WKT:
>         (unknown)
>         geom: Real (0.0)
>         as you see there is no problem to connect mysql and read
>         information
>         created mysql geometries from shape file also works here is an
>         example
>         MYSQL:testogr,user=root,password=mysqlpasswd,host=localhost,port=3306
>         iller -summary
>         INFO: Open of
>         `MYSQL:testogr,user=root,password=mysqlpasswd,host=localhost,port=3306'
>         successful.
>         Layer name: iller
>         Geometry: Polygon
>         Feature Count: 83
>         Extent: (26.026489, 35.820221) - (44.869179, 42.094917)
>         Layer SRS WKT:
>         GEOGCS["GCS_WGS_1984",
>            DATUM["WGS_1984",
>                SPHEROID["WGS_1984",6378137,298.257223563]],
>            PRIMEM["Greenwich",0],
>            UNIT["Degree",0.0174532925199433]]
>         FID Column = OGR_FID
>         Geometry Column = SHAPE2
>         area: Real (13.6)
>         perimeter: Real (13.6)
>         illerdd_: Real (0.0)
>         illerdd_id: Real (0.0)
>         il_kod: Real (2.0)
>         iladi: String (20.0)
>         Now I would like to learn what is wrong with my procedures...
>         please
>         help
>         Murat
>         On Tue, 2012-02-28 at 09:03 +0530, Chaitanya kumar CH wrote:
>         > Murat,
>         > Since it is MySQL it doesn't matter much how you store it.
>         If you are
>         > going to edit the end points later, storing them as points
>         is
>         > preferable, otherwise store them as wkt linestring
>         geometries.
>         > For your mapfile, first check if the extents are correct.
>         Then check
>         > if the mapfile works with a shapefile created from the
>         geometries in
>         > MySQL.
>         > On Tuesday, February 28, 2012, Murat BEYHAN wrote:
>         >         Chaitanya,
>         >         thanks for your repply,
>         >         Actually I use ogr and mysql to draw point for
>         example
>         >         epicenter of
>         >         earthquakes. But this is the first time to draw line
>         which is
>         >         stored in
>         >         Mysql as a table. Actually there is no problem on
>         drawing
>         >         shape file of the
>         >         line. But I would like to draw it using MySql and
>         ogr
>         >         functionality. So I
>         >         have only start and end point of line and I store it
>         on MySql
>         >         database then
>         >         I try to draw it considering id of the line by sql
>         statement.
>         >         Just I would lie to learn how to code it on
>         Mapserver map file
>         >         and how
>         >         should I store line on database as a start and stop
>         point of
>         >         the line or as
>         >         a geometry . Please help...
>         >         thanks
>         >         On Mon, 27 Feb 2012 22:09:52 +0530, Chaitanya kumar
>         CH wrote
>         >         > Murat,
>         >         > First check if your database is accessible using
>         ogrinfo[1].
>         >         > Then create a vrt file with the content you
>         specified in the
>         >         CONNECTION
>         >         > field of the mapfile. Check if ogrinfo gives
>         expected
>         >         results with this
>         >         > file.
>         >         > You probably have gdal executables if you are
>         running
>         >         mapserver.
>         >         > [1]: http://www.gdal.org/ogrinfo.html
>         >         > On Mon, Feb 27, 2012 at 12:48 PM, Murat Beyhan
>         >         > <beyhan at deprem.gov.tr> wrote:
>         >         > > Dear all,
>         >         > > I have shared this mail on Mapserver list but
>         could not
>         >         solve my
>         >         > > problem.
>         >         > > Still could not achieve to draw line using start
>         and stop
>         >         point line
>         >         > > data stored in MySql database.
>         >         > > I have tried Mr. Robert's solution but I have
>         faced an
>         >         error message.
>         >         > > in map file
>         >         > > I changed Geometrytype from wkbline to
>         wkblinestring.
>         >         > > LAYER
>         >         > > NAME sfault1
>         >         > > CONNECTIONTYPE OGR
>         >         > > <FID>eq_id</FID>
>         >         > > </OGRVRTLayer>
>         >         > >  DATA sfault1
>         >         > >  STATUS on
>         >         > >  TYPE line
>         >         > >  CLASS
>         >         > >  NAME "Source Fault"
>         >         > >  SYMBOL "cline"
>         >         > >   SIZE 3
>         >         > >  COLOR  0 0 255
>         >         > >  END
>         >         > > END
>         >         > > in database
>         >         > > I have two table
>         >         > > one is sfault which store
>         >         > > id lat1 lon1 lat2 lon2
>         >         > > and another is lineview which is a view
>         >         > > of this table created by following
>         >         + " " + lat1
>         sfault
>         >         > > there is an another issue,
>         >         > > I have to draw line by considering id
>         >         > > so in the map When I select one id, line should
>         be belong
>         >         to this id's
>         >         > > information
>         >         > > so I have to make a sql statement as follow
>         instead of
>         >         draw all line
>         >         > > stored in database I have to draw just one line
>         >         considering id
>         >         > > something like this:
>         >         > > select eq_id, geom from lineview where id like
>         '%id%'
>         >         > > please help about this subject....
>         >         > > Regards....
>         >         > > Murat
>         >         > > This message has been scanned for viruses and
>         >         > > dangerous content by MailScanner, and is
>         >         > > believed to be clean.
>         >         > > _______________________________________________
>         >         > > gdal-dev mailing list
>         >         > > gdal-dev at lists.osgeo.org
>         >         > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>         >         > Best regards,
>         >         > Chaitanya kumar CH.
>         >         > +91-9494447584
>         >         > 17.2416N 80.1426E
>         >         Murat Beyhan
>         >         Jeofizik Yük. Müh.
>         >         T.C.
>         >         BAŞBAKANLIK
>         >         Afet ve Acil Durum Yönetimi Başkanlığı
>         >         Deprem Dairesi Başkanlığı
>         >         Eskişehir Yolu 12. Km. Lodumlu/Ankara
>         >         Tel:+90 (312) 2872680-1550
>         > Best regards,
>         > Chaitanya kumar CH.
>         > +91-9494447584
>         > 17.2416N 80.1426E
>         Murat BEYHAN
>         Jeofizik Y.Müh.
>         T.C. Başbakanlık
>         Lodumlu/ANKARA
>         Tel: 312 2872680-1556
>         email:beyhan at deprem.gov.tr
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Lodumlu/ANKARA
