[gdal-dev] Motion: Promote GDAL 1.9.0RC1 as GDAL 1.9.0 Final
William Kyngesburye woklist at kyngchaos.com
Mon Jan 2 20:20:11 EST 2012
One configuration problem so far on OS X:
- with-freexl - doesn't test for freexl with libiconv (I have freexl compiled as static library, so it doesn't automatically link libiconv).  I just added $LIBICONV to both the freexl tests to get this to work, but another test for whether freexl needs iconv is really needed.
And one compile error:
webpdataset.cpp:536: error: invalid conversion from 'int' to 'WebPEncCSP'
I changed the offending line to:
    sPicture.colorspace = WEBP_YUV420;
and it compiles.
If these can be fixed for 1.9.0 release that would be great, otherwise I'll add bug reports.
On Dec 31, 2011, at 7:38 PM, Frank Warmerdam wrote:
> Motion: To promote the GDAL/OGR 1.9.0RC1 release candidate as
>            the final GDAL/OGR 1.9.0 release.
> +1 Frank
> I have done a wee bit of testing and the release candidate seems
> solid.  Other PSC members are encouraged to test and vote.
> Feedback from other users is also welcome.
> Voting will remain open until at least the end of day on
> Tuesday.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
