[gdal-dev] WFS and -where with non-ASCII characters
Ari Jolma ari.jolma at gmail.com
Tue Jan 3 03:45:26 EST 2012
Jukka,
I get: ERROR 1: 'Hämeenkylä' not recognised as an available field.
I.e., it seems to not be confused with 'ä' - I'm using a linux, where
the terminal may be better with UTF8. However, the message confused me,
it is coming from OGR SQL engine, and it seems that the engine tries to
parse the constant as a field name.
The fix is to escape ', i.e., \'Hämeenkylä\', which works.
Ari
On 01/03/2012 10:01 AM, Jukka Rahkonen wrote:
> Hi,
> Next trouble with the WFS driver. How am I supposed to find a place named
> 'Hämeenkylä'?  The following request leads to an error telling me that there are
> forbidden characters.
> ogr2ogr -f "ESRI Shapefile" -spat 377346 6673628 392155 6684806 test.shp
> WFS:http://hip.latuviitta.org/cgi-bin/tinyows  lv:pks_tilastoalue_piste -where
> name='Hämeenkylä'
> I have met this same error with other clients usign http GET. I suppose that 'ä'
> characters should be given somehow escaped.
> -Jukka Rahkonen-
