[gdal-dev] Motion: Promote GDAL 1.9.0RC1 as GDAL 1.9.0 Final
William Kyngesburye woklist at kyngchaos.com
Tue Jan 3 21:46:42 EST 2012
OK, I have NetCDF now with HDF4/5 & DAP.  Now configure problems again (again, netcdf is static library, as are HDF4, HDF5 and DAP):
My netcdf needs curl (it defaults to using curl), but GDAL doesn't test netcdf with that (curl is tested much later).
Netcdf4 also needs some symbols from libhdf5_hl, but this is not checked for.
On Jan 3, 2012, at 4:49 PM, Etienne Tourigny wrote:
> Folks,
> I would appreciate minimal testing for netcdf-4 in osx before
> releasing rc2 (which should take a few days at the most).
> Wiliam:
> The driver in 1.9 includes support for netcdf-4, which uses hdf5 for
> storage and supports deflate compression as well as a new data model.
> Other important bugfixes and support for CF-1.5 have been included as
> well.There are also some new autotests that are skipped if netcdf-4 is
> not available to GDAL, if these pass the build should be fine.
> More details here:
> http://www.gdal.org/frmt_netcdf.html (Driver Improvements (GDAL >= 1.9.0) )
> http://trac.osgeo.org/gdal/wiki/NetCDF_Improvements
> configure script should detect netcdf-4 if it is installed (and
> nc-config can be found in the appropriate path), and if hdf5 is
> available to gdal and netcdf-4 was built with netcdf-4/hdf5 support
> (shared build). You might need to add --with-netcdf=path_to_netcdf if
> it doesn't get detected (right after hdf4 and hdf5 detection).
> I have sent a few emails to the list:
> http://lists.osgeo.org/pipermail/gdal-dev/2011-December/031116.html
> http://lists.osgeo.org/pipermail/gdal-dev/2011-October/030472.html
> Bug entries for netcdf-4 support (including some tests)
> http://trac.osgeo.org/gdal/ticket/3890
> http://trac.osgeo.org/gdal/ticket/2379
> http://trac.osgeo.org/gdal/ticket/4408
> Wiliam, if have any problems building I'll be happy to help, and if
> any of the tests fail please file a bug report.  I am on vacation but
> have access to internet at night.
> regards,
> Etienne
> On Tue, Jan 3, 2012 at 11:47 AM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> I've always built netcdf without v4 API because GDAL didn't support it.  I missed that addition in GDAL 1.9, so it looks like I have more work for compilation and testing ;)
>> I saw some time ago that HDF5 added some capbility for integration with netcdf4, GDAL 1.9 supports this now?
>> On Jan 3, 2012, at 8:04 AM, Etienne Tourigny wrote:
>>> William,
>>> Can you comment on the status of support for netcdf4 + hdf5 in mac osx
>>> ? Has that been tested, or is it possible to include them in your
>>> builds?
>>> There have been a number of improvements to the netcdf driver for
>>> 1.9.0 (including support for netcdf-4), it would be nice to have that
>>> included in your builds.  If you need help I can try to assist, but I
>>> don't have a mac nor experience with osx.
>>> thanks,
>>> Etienne
>>> On Mon, Jan 2, 2012 at 10:20 PM, William Kyngesburye
>>>> One configuration problem so far on OS X:
>>>> - with-freexl - doesn't test for freexl with libiconv (I have freexl compiled as static library, so it doesn't automatically link libiconv).  I just added $LIBICONV to both the freexl tests to get this to work, but another test for whether freexl needs iconv is really needed.
>>>> And one compile error:
>>>> webpdataset.cpp:536: error: invalid conversion from 'int' to 'WebPEncCSP'
>>>> I changed the offending line to:
>>>>    sPicture.colorspace = WEBP_YUV420;
>>>> and it compiles.
>>>> If these can be fixed for 1.9.0 release that would be great, otherwise I'll add bug reports.
>>>> On Dec 31, 2011, at 7:38 PM, Frank Warmerdam wrote:
>>>>> Motion: To promote the GDAL/OGR 1.9.0RC1 release candidate as
>>>>>            the final GDAL/OGR 1.9.0 release.
>>>>> +1 Frank
>>>>> I have done a wee bit of testing and the release candidate seems
>>>>> solid.  Other PSC members are encouraged to test and vote.
>>>>> Feedback from other users is also welcome.
>>>>> Voting will remain open until at least the end of day on
>>>>> Tuesday.
>>>>> Best regards,
>>>>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>>>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>>>> and watch the world go round - Rush    | Geospatial Software Developer
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
>>>> - the wisdom of Tarzan
>> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
>> - Marvin
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
