[gdal-dev] Reading OGRStyle information using C++
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 5 06:25:14 EST 2012
Aneesh,
A layer can have a style table that stores a set of styles that can be
referred by individual features. Usually the style table has a default
style.
Its usage is explained in the same page as the OGR Feature Style
Specification.
On Thu, Jan 5, 2012 at 3:45 PM, Aneesh Muralidharan <symonando at gmail.com>wrote:
> Hi,
> I'm new to OGR/GDAL and I'm trying to read style information of vectors
> using the OGR C++ API. I followed the documentation available here
> http://www.gdal.org/ogr/ogr_feature_style.html. I have managed to get the
> pen information of the glyphs' in vector file successfully.
> The problem is that, it is unclear that from where can I figure out the
> layer style specification. i.e the global style for the layer ( assuming
> each glyph's pen can be either one of its own or dependent on the layer ).
> The OGRFeatureDefn for the OGRLayer doesn't seem to have this information.
> Also is there any detailed explanation of the API somewhere with some
> sample code snippets ? (for the feature-style api. For read/write I know
> there is http://www.gdal.org/ogr/ogr_apitut.html)
> Hoping for a quick response
> Thanks and regards,
> Aneesh Muralidharan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120105/c63987e4/attachment.html
