[gdal-dev] Open Grib File
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 5 07:00:24 EST 2012
Pascal,
First check if your file works with the gdalinfo utility. Set the
environment variable CPL_DEBUG to ON to get more detailed reports on events.
Check if you get the same error with another grib file and another format
file.
On Thu, Jan 5, 2012 at 2:50 PM, Jaugeas, Pascal (External) <
pascal.jaugeas.External at cassidian.com> wrote:
> Hello,
> I develop with Gdal for .Net.
> And I try to read a grib File (ed 1) like this :
> Dataset
> ds = Gdal.Open(dataSourcePath, Access.GA_Update);
> with dataSourcePath is the path of grib file (.grb).
> But I have an error in debug : "... not recognised as a supported file
> format."
> Is this method correct to have a dataset of a grib file ?
> Thank you for your help,
> Best Regards,
> Pascal Jaugeas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120105/30e65cab/attachment.html
