[gdal-dev] Reading OGRStyle information using C++
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 5 08:22:30 EST 2012
Aneesh,
Actually, I just reviewed the driver code. It's not documented.
I don't know enough to suggest any format for efficiently storing style
info. But you can start with MapInfo, KML and DXF.
On Thu, Jan 5, 2012 at 6:06 PM, Aneesh Muralidharan <symonando at gmail.com>wrote:
> Chaithanya,
> Ahhh that explains it ! Thanks a lot. By the way where do I find out these
> information (like DXF driver doesn't support style table), as in where is
> it documented ?
> And can you suggest me some other vector format that OGR loads by default,
> which has style information ? I was using SHP till now, but then it doesn't
> have the style information at all right. Also it will be great if you can
> point me to some place where I can find some free samples as well.
> On Thu, Jan 5, 2012 at 5:51 PM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> > wrote:
>> Aneesh,
>> I don't know if the DXF format maintains a default style or a style table
>> but OGR's DXF driver doesn't support layer's style table.
>> On Thu, Jan 5, 2012 at 5:30 PM, Aneesh Muralidharan <symonando at gmail.com>wrote:
>>> Hi Chaithanya,
>>> Thanks for the quick reply
>>> About the style table, I did try to use the layer style table, but I'm
>>> getting an empty table :(
>>> By the way I'm trying to read a simple DXF file.
>>> On Thu, Jan 5, 2012 at 4:57 PM, Chaitanya kumar CH <
>>> chaitanya.ch at gmail.com> wrote:
>>>> A layer's style table can be accessed using OGRLayer::GetStyleTable()
>>>> [1].
>>>> [1]: http://www.gdal.org/ogr/classOGRLayer.html
>>>> On Thu, Jan 5, 2012 at 4:55 PM, Chaitanya kumar CH <
>>>>> Aneesh,
>>>>> A layer can have a style table that stores a set of styles that can be
>>>>> referred by individual features. Usually the style table has a default
>>>>> style.
>>>>> Its usage is explained in the same page as the OGR Feature Style
>>>>> Specification.
>>>>> On Thu, Jan 5, 2012 at 3:45 PM, Aneesh Muralidharan <
>>>>> symonando at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I'm new to OGR/GDAL and I'm trying to read style information of
>>>>>> vectors using the OGR C++ API. I followed the documentation available here
>>>>>> http://www.gdal.org/ogr/ogr_feature_style.html. I have managed to
>>>>>> get the pen information of the glyphs' in vector file successfully.
>>>>>> The problem is that, it is unclear that from where can I figure out
>>>>>> the layer style specification. i.e the global style for the layer (
>>>>>> assuming each glyph's pen can be either one of its own or dependent on the
>>>>>> layer ). The OGRFeatureDefn for the OGRLayer doesn't seem to have this
>>>>>> information.
>>>>>> Also is there any detailed explanation of the API somewhere with some
>>>>>> sample code snippets ? (for the feature-style api. For read/write I know
>>>>>> there is http://www.gdal.org/ogr/ogr_apitut.html)
>>>>>> Hoping for a quick response
>>>>>> Thanks and regards,
>>>>>> Aneesh Muralidharan
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Best regards,
>>>>> Chaitanya kumar CH.
>>>>> +91-9494447584
>>>>> 17.2416N 80.1426E
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120105/ec240555/attachment.html
