[gdal-dev] To to create HDF4 files for GDAL
Andreas H. lists at hilboll.de
Thu Jan 5 09:15:47 EST 2012
Hi there,
when creating HDF4 files outside of GDAL, which metadata do I have to
write to
the file such that GDAL can subsequently correctly read the data? In the docs
I read that only HDF4 files created with GDAL or certain other HDF4 types are
recognized. However, the files are created "by hand" using the HDF4 API from
Delphi. I would like to modify this creation in a way such that GDAL can read
the data.
The HDF files follow the "Scientific DataSet (SDS)" standard. When reading
the files with GDAL, it looks like this:
   $ gdalinfo datafile.hdf
   Driver: HDF4Image/HDF4 Dataset
   Files: datafile.hdf
   Size is 2880, 1440
   Coordinate System is `'
   Metadata:
     _FillValue=-nan
     long_name=VCDstrat NO2
   Geolocation:
     SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
     X_DATASET=HDF4_SDS:UNKNOWN:"datafile.hdf":2
     X_BAND=1
     Y_DATASET=HDF4_SDS:UNKNOWN:"datafile.hdf":1
     Y_BAND=1
     PIXEL_OFFSET=0
     PIXEL_STEP=1
     LINE_OFFSET=0
     LINE_STEP=1
   Corner Coordinates:
   Upper Left  (    0.0,    0.0)
   Lower Left  (    0.0, 1440.0)
   Upper Right ( 2880.0,    0.0)
   Lower Right ( 2880.0, 1440.0)
   Center      ( 1440.0,  720.0)
   Band 1 Block=2880x347 Type=Float32, ColorInterp=Gray
Obviously, georeferencing is not working. What do I need to do to the HDF4
file to fix this?
Thanks for your insight,
Andreas.
PS: In case anyone is interested, here's the reason why I want to do this:
I have a whole lot of HDF4-SDS files which I want to plot using GMT. So I
thought using gdal_translate to convert the HDF4 to GRD would be the easiest
solution. I'm using GDAL 1.8.1 .
However, I'm running into problems which I'm detailing below:
I guess the problem is that GDAL doesn't read the SDS's latitude/longitude
information. When converting this file then to GMT's grd format, I get a
warning, which I guess doesn't really matter too much:
   $ gdal_translate -of GMT datafile.hdf test.grd
   Warning 6: A dataset opened by GDALOpenShared should have the same
filename (datafile.hdf) and description
(HDF4_SDS:UNKNOWN:"datafile.hdf":0)
   Input file size is 2880, 1440
The resulting grd file looks like this:
   $ gdalinfo test.grd
   Driver: GMT/GMT NetCDF Grid Format
   Files: test.grd
          test.grd.aux.xml
   Size is 2880, 1440
   Origin = (0.000000000000000,0.000000000000000)
   Pixel Size = (1.000000000000000,1.000000000000000)
   Metadata:
     _FillValue=-nan
   Corner Coordinates:
   Upper Left  (   0.0000000,   0.0000000)
   Lower Left  (       0.000,    1440.000)
   Upper Right (    2880.000,       0.000)
   Lower Right (    2880.000,    1440.000)
   Center      (    1440.000,     720.000)
   Band 1 Block=2880x1 Type=Float32, ColorInterp=Gray
When I now try to plot this file using grdimage, I get the following:
   grdimage: GMT ERROR: grid y increment <= 0.0
   grdimage: Use grdedit -A on your grid file to make region and
increments compatible [test.grd]
However, running the suggested grdedit -A test.grd doesn't change a thing ...
