[gdal-dev] Shifting raster image one meter
Andreas Neumann a.neumann at carto.net
Mon Jan 9 11:06:07 EST 2012
 Due to some error that I cannot easily reproduce one orthoimage is one
 meter offset. Luckily the shift is constant throughout the image.
 What is the easiest way to shift this image back one meter (east-west)
 with gdal utilities? I browsed through the gdal_translate and gdal_warp
 documentation but couldn't find an easy way to translate an image
 without changing the projection.
 Should I edit the world file? The image is a geotiff, so it doesn't
 have a worldfile.
 Thanks for any ideas.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
