[gdal-dev] Shifting raster image one meter
Andreas Neumann a.neumann at carto.net
Mon Jan 9 11:51:51 EST 2012
 Thanks, Jean-Claude,
 I will give it a try tomorrow!
 Andreas
 On Mon, 09 Jan 2012 17:23:17 +0100, Jean-Claude Repetto wrote:
> Le 09/01/2012 17:06, Andreas Neumann a écrit :
>> Should I edit the world file? The image is a geotiff, so it doesn't
>> have
>> a worldfile.
>> Thanks for any ideas.
>> Andreas
> Hi,
> You can use the new utility gdal_edit.py (in GDAL 1.9) to edit
> GeoTiff metadata.
> Frank, Even : It would be useful to add this utility to the
> documentation page at http://www.gdal.org/gdal_utilities.html .
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
