[gdal-dev] Re: GDAL JP2KAK plugin for lossless 16 bit
Nikoko pinchon.nicolas at gmail.com
Mon Jan 16 11:23:28 EST 2012
Hello,
I have the same problem with lossless unsigned integer (16 bits). See my
ticket :  http://trac.osgeo.org/gdal/ticket/4050
I tried with the last GDAL version 1.9.0 but this bug is not fixed yet. Did
someone find the cause of the problem ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-GDAL-JP2KAK-plugin-for-lossless-16-bit-tp6053172p7193104.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
