[gdal-dev] How create a spatial index for shapefiles
aperi2007 aperi2007 at gmail.com
Sun Jan 22 06:48:33 EST 2012
thx for hint.
I wrongly try to use the ogr2ogr. :)
Andrea.
Il 22/01/2012 12:04, Chaitanya kumar CH ha scritto:
> The SQL command to create a spatial index can be given through ogrinfo.
> ogrinfo -sql"CREATE SPATIAL INDEX ON file1 [DEPTH N]"  file1.shp
> On Sun, Jan 22, 2012 at 3:48 PM, Even Rouault
> <even.rouault at mines-paris.org <mailto:even.rouault at mines-paris.org>> wrote:
>     Le dimanche 22 janvier 2012 11:14:22, aperi2007 a écrit :
>      > Hi,
>      > I'm try-ing to export from spatialite to shapefile using ogr2ogr.
>      > it work but I like to procude also the spatial-index file .qix.
>      > I don't find any option to do this for shapefile.
>      > Is this possible ?
>     Yes, see the "Spatial and attribute indexing" section of
>     http://gdal.org/ogr/drv_shapefile.html
>      > Thx,
>      > Andrea.
>      > _______________________________________________
>      > gdal-dev mailing list
>      > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>      > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
