[gdal-dev] GDAL 1.7.3 java bindings on Centos 5 (64 bit)
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Mon Jan 23 12:12:14 EST 2012
Hi list,
Does anyone have any experience about the reported topic?
I have downloaded GDAL 1.7.3 on my Centos 5.7 (64) machine and built it
(with only base drivers and with threads support).
Utilities are working fine (gdalinfo, gdal_translate, ...)
Then, I have installed SWIG 1.3.36 (I know, it's quite old but testing
1.3.4X or 2.x in the past, I got several JVM crashes or other types of
issues) and I have created java bindings for it.
Once I have configured LD_LIBRARY_PATH to use all SOs it needs, I have
started running some ImageIO-Ext tests with maven and JVM is crashing.
In case someone don't know it, ImageIO-Ext mainly allows to bridge Java's
ImageIO (ImageReaders/writers/SPI) to GDAL format drivers.
On several Ubuntu (8, 9, 10, 11) I never had similar problems. We regularly
use ImageIO-Ext 1.1.2 built on top of GDAL 1.7.3 on projects like GeoTools,
GeoServer, Udig, ... Therefore I guess it's not a problem on the
ImageIO-Ext caller side. I think it could be related to the SWIG-JNI
counterpart which isn't working properly or something odd with the memory
usage.
Does anyone have any feedback on this? (supported/never tested/won't
work/need some CXX flags/... anything)
I'm pasting the hs_err_pid Log in case you find anything interesting.
[1]: http://pastebin.com/WQkfnutJ
Thanks in advance and best regards,
Daniele
ERROR: native gdal on centos 64 bit
 T E S T S
Running it.geosolutions.imageio.plugins.arcgrid.ArcGridReadTest
Jan 23, 2012 11:42:45 AM it.geosolutions.imageio.gdalframework.GDALUtilities
loadGDAL
INFO: GDAL Native Library loaded (version: 1.7.3)
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00002b15a3ba7037, pid=9169, tid=1106860352
# JRE version: 6.0_29-b11
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.4-b02 mixed mode
linux-amd64 compressed oops)
# Problematic frame:
# V  [libjvm.so+0x4e1037]  java_lang_String::utf8_length(oopDesc*)+0x67
# An error report file with more information is saved as:
# /root/tests/imageio1.1.2/plugin/gdal/gdalarcgrid/hs_err_pid9169.log
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
/bin/sh: line 1:  9169 Aborted
/usr/lib/jvm/jdk1.6.0_29/jre/bin/java
-Xmx512M -enableassertions -Dtest.extensive=false -Dtest.interactive=false
-jar /tmp/surefirebooter8850919397384240961.jar
/tmp/surefire7943635768826345743tmp
/tmp/surefire4074398420042204599tmp
Ing. Daniele Romagnoli
GeoSolutions S.A.S.
Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 962313
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120123/37792dc9/attachment.html
