[gdal-dev] ElasticSearch Driver
Even Rouault even.rouault at mines-paris.org
Tue Jan 24 16:13:31 EST 2012
Le mardi 24 janvier 2012 21:27:03, Adam Estrada a écrit :
> All,
> I have been using ElasticSearch as a way to perform some advanced analysis
> on feature attribute data. From my work with ElasticSearch came the
> ogr2elasticsearch GDAL driver. The code can be found here.
> http://code.google.com/p/ogr2elasticsearch/
> Every time I rebuild GDAL I have to add this driver back to the build path
> so that I can take advantage of it which is unfavorable. What would it take
> to get this driver included in to trunk GDAL?
* Make sure that it works with the json-c already in
ogr/ogrsf_frmts/geojson/jsonc
* Write a drv_elasticsearch.html page (but I see you have the material for
that on the google project). Perhaps make it clearer that it is a write-only
driver. Out of curiousity, any plan to add a read operation (if that makes
sense. I've never used elasticsearch). Also mentions that the geometry written
in ElasticSearch is the center of the bounding box of the geometry (for linear
or polygonal geometries).
* in OGRElasticDataSource constructor, I suspect bUseExtension is from another
driver and should be removed. Same for bWriteHeaderAndFooter. And removed from
the header file too
* in OGRElasticDataSource::Create() :
	- you should make a copy of the return of CPLGetConfigOption() for
psWriteMap and psMetaFile. The reason is that if their values is changed later
the pointer might become invalid. By the way, the standard hungarian notation
for char* is psz. Ah and you should make sure they are initialized in the
constructor and freed in the destructor of the class.
        - actually, I see that psMetafile is only used in Create(). So why make
it a member variable of the class ?
        - there's a missing fclose(fp)
        - psMapping (which should be pszMapping) is never freed apparently ?
* in ogr_elastic.h :
*in OGRElasticLayer definition :
	- nTotalFeatureCount should likely be removed. It is null-initialized,
incremented in CreateFeature() but never used elsewhere
	- poFeature should be removed. It is null-initialized in the constructor
and deleted in the destructor, but never initialized to something else.
* in OGRElasticLayer::~OGRElasticLayer(), poFeatureDefn->Release() should be
uncommented, otherwise you're leaking it
* in OGRElasticLayer::BuildMap(), the comment // The attribute's were freed
from the deletion of the map object and the nullifying of pAttributes are
strange. I can see pAttributes being initialized in CreateField(), but never
destroyed.
* in OGRElasticLayer::CreateFeature(), :
     - you dereference poFeature->GetGeometryRef(), assuming that it is always
non NULL. Which might not be always the case...
     - in the loop iterating over field, you should likely test IsFieldSet(i)
before calling GetFieldAs...() in the case the field is unset/null.
     - GetFieldAsInteger(), GetFieldAsDouble() and GetFieldAsInteger() can
accept the index also as an argument : this will make the code shorter (and
also a bit faster)
And after that and checking that it still works, attach a patch in Trac ;-)
> Thanks in advance,
> Adam
